How can i apply these settings to voukouder? (x265)
  • How can i apply these to vokouder With x265 CRF? Even screenshots from what to select would be helpful.
    Closed GOP (<=2B-frames, Adaptive I-Frames, Adaptive B-frames)
    Fixed KFI of 1/2 Framerate (not sure does this require info about my fps im using 60fps always)
    - Optimize for high SSIM
  • Jorma12 17. April 2022 um 22:39
    Hat den Titel des Themas von „How can i apply these settings to vokouder? (x265)“ zu „How can i apply these settings to voukouder? (x265)“ geändert.
  • Vouk 18. April 2022 um 07:07
  • Hi, afaik currently there are no available presets. I've created a pull request to submit them and it needs time to be tested and updated to next/later release. Currently you need to go to Option tab, and find, apply the settings yourself :)
