Hi there,
I downloaded the two files and installed them on my Win10 Pro Premiere Pro CC (current version) system. I don't see how to access Voukoder to save anything. I assume it should show up in the encode panel?
Anyway, I REALLY need to be able to encode mp2 files for broadcast tv WITH embedded captions. Does Voukoder do that?? If not, can the feature be added?
Thank you,
Wayland
Thank you again. I tried Voukoder by selecting it under format (as your image showed) and selected mp2 on export. I don't see a way to do embedded closed captions. The captions control only shows burn-in and create a sidecar file. I need them embedded into the video file for broadcast television use.
Still, I look forward to experimenting with Voukoder.
Thank you and Best Wishes,
Wayland
There is a single format that seems to do the embedded captions but many stations only want mpeg 2 files. The format is MXF OP1. If you create a timeline and add a sample caption over the exporting video/audio you can see in the export menu the options to export burn-in, create a sidecar file (.mcc or .scc) and embed captions.
I hope this help to explain in more detail what I am after.
Thanks,
Wayland
