So, having some problems with rendering in HEVC NVENC in vegas pro 15 and 14 (tried both. I don't think its the problem with them).
The same issue as couleur mentioned. Any ideas of fixing or what can cause this issue?
https://pastebin.com/HMDx4Fy4
Using HEVC NVENC instantly "finishes" the render
- VEGAS Pro
Latke -
28. Juni 2022 um 18:22
29. Juni 2022 um 16:01 Hat das Thema freigeschaltet. -
Can you enable "low level debugging" in the settings and share the logfile again?
Same in Vegas pro 19, it renders straight to 100% with any setting.
The encoder failed to start, and was not able to send a "fail" API call to Voukoder (my theory), probably are because of those unsupported graphic cards
Please try to upgrade to Voukoder 11.2
Does this help?
P.S.: This can also happen if you feed interlaced videos to RTX 20xx (or newer)
