Rendering FFV1 with Resolve and framemd5 control
  • Hi all,
    I have a question about Voukoder plugin for Resolve. In fact, i used ffmpeg command line to generate a FFV1 file and a log file.
    The FFV1 file was encoded with a pixfmt rgb48be . Now with the plugin, the file is encode with a pixfmt rgba64le. It's a problem when i tried to verify the framemd5 :
    I launch with ffmpeg command line a framemd5 for the DPX files. I extract the DPX files from the FFV1 file and launch the framemd5 control file.
    The hashes are different between the files.
    I try the same with the FFV1 generated with ffmpeg command line. The framemd5 files are the same.
    Thanks for helping.
    Regards
  • Vouk 12. Oktober 2022 um 18:56
