Hi!
Sorry for my english but I have a problem with export of AV1 HDR content with or without your plugin. I have both Davinci Resolve and Adobe Premier. Mostly i use Davinci and i tried your plugin to export an edited HDR video with the new codec AV1 but whatever i chose - the end result is in SDR with clipped brightness. I tried 8 and 10 bit, default setting and not - no luck. In Adobe Premier the same thing with the plugin. The video is recorded in OBS with AV1 in HDR and it works perfectly. Can you help me with a tutorial or correct settings how to set the plugin correctly to export videos in AV1 HDR? And how to utilise dual encoders of my RTX 4090? I can't see an option to enable them both to work simulteniously to speed up the process.
BTW - by using Davinci only which have implemented Nvidia AV1 support i can't export my video in HDR neither. It's not recognised HDR in the MediaInfo, and the indication that it is in 10 bit dissapears after exporting - maybe someone can help me with setting up Davinci Resolve for it too?
I record mostly gameplay by using OBS or capture card. Would realy appreciate any help cause i wasted 5 days in finding a solution, but no luck(((.
