Hi there,
I had 2 questions about Vokouder.
Is it possible to use it in Adobe Media Encoder? If so, how? As I've seen nothing about it on the installation guide.
And second question. Is Vokouder really faster/Better then just H.265 using Adobe Media Encoder?
Thank you!
Questions about Voukoder
12. Januar 2023 um 13:45 Hat das Thema freigeschaltet. -
I just added this information.
Yes.
Where has this been added? As when I look at the installation it now says Premiere pro/Media Encoder, but when I install it, it just installs for Premiere pro?
Yes.
How is that possible? That means the stuff you make is better then something a billion dollar company makes, that's really impressive!
