MPEG2
  • WHY DOES NOT APPEAR MPEG2 IN MY VOUCODER ENCODER ?
    PLEASE HELP.. :/ :)
    PLEASE HELP.. :/ :)
    Einmal editiert, zuletzt von Vouk (6. Februar 2023 um 11:43) aus folgendem Grund: Ein Beitrag von ACIK mit diesem Beitrag zusammengefügt.
  • Vouk 6. Februar 2023 um 10:12
  • Too Old? For those of use that still need to create DVDs, MPEG2 is the only option.
    My suggestion to ACIK is that assuming the source is in Premiere, use Debug Framesever -> TMPGEnc Video Mastering Works. Create a template in VMW for the DVD style you need. It's how I've been doing it for years at the quality is way better than stock Adobe. It's not fast but it will work.
