VEGAS Pro 14 Steam Edition x265 crash
    First time user here and barely knows anything.
    wanted to output to HEVC so google says Voukoder anyway my vegas crashs whenever I choose it.
    Problem Description
    Application Name: VEGAS Pro
    Application Version: Version 14.0 (Build 271) 64-bit
    Problem: Unmanaged Exception (0xe06d7363)
    Fault Module: C:\WINDOWS\System32\KERNELBASE.dll
    Fault Address: 0x00007FFE72EFCB69
    Fault Offset: 0x000000000002CB69
  • Vouk 29. April 2023 um 12:31
  • Same problem with Vegas Pro 14 non-Steam version. This happens when using voukoder to render using any codec. Rendering using Vegasnon-voukoder engines work just fine, so it might be the connector.
    Voukoder versions: 12.2, 13.1
    Voukoder connector version: 1.5.0
    Vegas Pro: 14
    Windows Version: Windows 11 22H2 (22621.1105)
    Zitat
    VEGAS Pro 14.0
    Version 14.0 (Build 270) 64-bit
    Exception 0xE06D7363 (Unknown Type) IP:0x00007FFB35A006BC
    In Module 'KERNELBASE.dll' at Address 0x00007FFB35970000 + 0x00000000000906BC
    Thread: ProgMan ID=0x8B8 Stack=
    The log doesn't have anything interesting. But uploading anyway.
  • Ok. An update. At least for my project, I noticed the framerate is non-standard. I don't know when I changed it but it was 36 fps rather than the standard 24/25/30/50/60. You can see it in my log file with the line Timebase.
    I went into the project properties to adjust it to 29.970 (which is Vegas' option for 30 fps). After this, I can rendering the project without crashing.
    It doesn't seem that important to be rendering non-standard frame rates, so it is a low priority.
    Yes, that looks a bit suspicious.
    [18:36:03] Timebase:        63937/2360865 (36.92 fps)
    I'm pretty sure some encoders or formats/muxer could have problems with it
