Rendering issue in vegas pro 19
  • Vouk 20. Mai 2023 um 11:41
    [10:43:23] - Audio -------------------------------------
    [10:43:23] Timebase:        1/192000
    [10:43:23] Channels:        2
    [10:43:23] Encoder:         aac
    [10:43:23] Options:         _sampleFormat=fltp b=320000 profile=aac_low
    [10:43:23] Side data:       <none>
    [10:43:23] Filters:         filter.adelay#delays=8525S:all=1
    You have set a sample rate of 192 kHz in your audio settings in VEGAS Pro. But ...
    Encoder aac [AAC (Advanced Audio Coding)]:
        Supported sample rates: 96000 88200 64000 48000 44100 32000 24000 22050 16000 12000 11025 8000 7350
    ... AAC only supports up to 96 kHz.
    Usually this is set to 48 kHz - which should work perfectly.
