Failed opening codec: hevc_nvenc
  • When i try to render a Project with NEVC it crashes . All other Codecs are working
    [12:42:53] =============================================
    [12:42:53] Voukoder 12.1 (12.1.2)
    [12:42:53] by Daniel Stankewitz
    [12:42:53] ---------------------------------------------
    [12:42:53] 13th Gen Intel(R) Core(TM) i9-13900KF
    [12:42:53] 32 logical cores
    [12:42:53] 32625 MB system memory
    [12:42:53] Display #0 on: NVIDIA GeForce RTX 4080
    [12:42:53] Display #1 on: NVIDIA GeForce RTX 4080
    [12:42:53] Export started
    [12:42:53] Filename: C:\Users\User\Documents\Test.mp4
    [12:42:53] Application: Voukoder (VEGAS)
    [12:42:53] - Video -------------------------------------
    [12:42:53] Frame size: 3840x2160
    [12:42:53] Pixel aspect: 1:1
    [12:42:53] Timebase: 1/60 (60.00 fps)
    [12:42:53] Interlaced: Top first
    [12:42:53] Encoder: hevc_nvenc
    [12:42:53] Options: _computeCapability=8.9 _pixelFormat=p010le gpu=0 preset=p7 profile=main10 qp=15 rc=constqp tier=high tune=hq
    [12:42:53] Side data: <none>
    [12:42:53] Filters: filter.zscale#filter=bicubic|height=2160|width=3840
    [12:42:53] Passes: 1
    [12:42:53] Color range: unknown
    [12:42:53] Color space: unknown
    [12:42:53] Color primaries: unknown
    [12:42:53] Color transfer: unknown
    [12:42:53] - Audio -------------------------------------
    [12:42:53] Timebase: 1/48000
    [12:42:53] Channels: 2
    [12:42:53] Encoder: aac
    [12:42:53] Options: _sampleFormat=fltp b=320000 profile=aac_main
    [12:42:53] Filters: filter.adelay#delays=2131S:all=1
    [12:42:53] Opening codec: hevc_nvenc with options: gpu=0|preset=p7|profile=main10|qp=15|rc=constqp|tier=high|tune=hq
    [12:42:53] Failed opening codec: hevc_nvenc
    [12:42:53] Unable to open video encoder: hevc_nvenc
    [12:42:53] Closing encoders ...
    [12:42:53] Opening encoder failed! Aborting ...
    [12:42:53] Unable to open encoder.
  • Vouk 18. Juni 2023 um 13:19
