Failed opening codec: libopus
  • Voukoder failed when exporting the video, and I found it in the log that it failed opening the encoder 'libopus'.
  • Vouk 27. Juni 2023 um 12:36
  • Can you enable low level debugging in the settings and share the logfile again?
    I've confirmed that the problem is that opus codec doesn't support sampling rate of 44.1khz.
    Maybe voukoder can ban the option when using opus for output.
