I noticed FFVHuff isn't an option available, but it's an encoding option available in FFMPEG, available in 8, 10, and 16 variants and variable color spaces. Is there means to add this option myself, or are there any plans to include it? It's a fairly popular archiving format, since it's high quality, and may be larger than FFV1 but is infinitely better to work with in comparison in NLEs and VS.  ![]()
Support for FFVHuff (HuffYUV) and other UTvideo codec options
norrymk2  -
3. Juli 2023 um 15:10
3. Juli 2023 um 19:48 Hat das Thema freigeschaltet. -
Do you mean this one?
Alles anzeigenEncoder ffvhuff [Huffyuv FFmpeg variant]: General capabilities: dr1 threads Threading capabilities: frame Supported pixel formats: yuv420p yuv422p yuv444p yuv411p yuv410p yuv440p gbrp gbrp9le gbrp10le gbrp12le gbrp14le gbrp16le gray gray16le yuva420p yuva422p yuva444p gbrap yuv420p9le yuv420p10le yuv420p12le yuv420p14le yuv420p16le yuv422p9le yuv422p10le yuv422p12le yuv422p14le yuv422p16le yuv444p9le yuv444p10le yuv444p12le yuv444p14le yuv444p16le yuva420p9le yuva420p10le yuva420p16le yuva422p9le yuva422p10le yuva422p16le yuva444p9le yuva444p10le yuva444p16le rgb24 bgra ffvhuff AVOptions: -non_deterministic <boolean> E..V....... Allow multithreading for e.g. context=1 at the expense of determinism (default false) -pred <int> E..V....... Prediction method (from 0 to 2) (default left) left 0 E..V....... plane 1 E..V....... median 2 E..V....... -context <int> E..V....... Set per-frame huffman tables (from 0 to 1) (default 0)Yes, I might add that.
Edit: Added it to VoukoderPro.
That's correct, you're the best!! Joining your patreon later on today, appreciate all of your hard work.
