The power of the "Test scene" button
    Are you in a situation like this?
    • You have just created a new VoukoderPro-Scene and you'd like to know if this would work?
    • Your NLE denies to render using a VoukoderPro-Scene?
    It's a good practice to perform a test run first in such a case. Just click the blue play-button or select "Tools > Test scene ..." from the menu.
    Clicking this will open a new dialog:
    By clicking the start button it will try to render one empty video frame and empty audio samples using the currently open scene without your NLE. It tests if it can initialize all nodes, render trough that nodes and then - instead of writing it to a file - it throws everything away.
    But you'll see a detailed log in that window which you can check for yourself or you can send it to this forum for help.
