Voukoder presets not showing in appdata and Render As
  • Hello. I installed Voukoder and connector for Vegas 20. The presets show neither in Vegas>Render As, nor in AppData\Roaming\VEGAS\Render Templates\voukoder. I tried to download them separately but didn't find a way. Could you help? Regards
  • Vouk 12. August 2023 um 14:24
  • It started to work before I could do as you said. I picked different options in the installer: "install", "repair" and "remove", and also rebooted the program and the computer several times. After an x-th time, voukoder just showed up in the list, I don't know why.
