Exporting at wrong frame rate
  • I was trying to render some graded DJI Air2s footage -> 5472x3078 23,976 fps on a timeline with the same settings using ProRes 422 in a Quicktime Container, exporting them as individual clips. The problem is all my clips turn out to be 59.94fps after export.
    Tried rendering again not using Voukoder and didn't run into issues.
  • Vouk 18. August 2023 um 14:11
    [11:44:27] - Video -------------------------------------
    [11:44:27] Frame size:      5472x3078
    [11:44:27] Pixel aspect:    1:1
    [11:44:27] Timebase:        1001/24000 (23.98 fps)
    [11:45:41] - Video -------------------------------------
    [11:45:41] Frame size:      5472x3078
    [11:45:41] Pixel aspect:    1:1
    [11:45:41] Timebase:        1001/60000 (59.94 fps)
    [11:46:43] - Video -------------------------------------
    [11:46:43] Frame size:      5472x3078
    [11:46:43] Pixel aspect:    1:1
    [11:46:43] Timebase:        1001/60000 (59.94 fps)
    [11:48:11] - Video -------------------------------------
    [11:48:11] Frame size:      5472x3078
    [11:48:11] Pixel aspect:    1:1
    [11:48:11] Timebase:        1001/60000 (59.94 fps)
    The first one was started with 23.98 fps. The other 3 ones with 59.94. Voukoder uses the framerate you have set in your NLE. Can you double check it's really set to 23.98 fps in DVR?
    This is most likely not a Voukoder issue.
  • Well this is awkward, it seems resolve uses each clip settings instead of the timeline ones but I only happened to check the other files and not the 1st one. I'm sorry
