Downloaded & installed vegas connector 1.5.0 and the voukoder 13 setup.
the codec h.265 doesnt seem to have loaded into my copy of Vegas 13.
Any sugestions ?
Vegas connector 1.5.0 Didnt Work
						- VEGAS Pro
						wlreynajr
					23. August 2023 um 17:32
			  Vouk23. August 2023 um 18:00 Hat das Thema freigeschaltet.
 What exact encoder are you trying to use? If it's NVENC try to update you driver software.
			the codec h.265 doesnt seem to have loaded into my copy of Vegas 13. Voukoder doesn't 'load any codecs into Vegas'. It won't give Vegas 13 the ability to open h.265 files. What it DOES do is give you a way to encode your video in Vegas 13 as h.265 using Voukoder in the Render As menu. Depending on your computer's capabilities, Voukoder can perform h.265 encoding by using either software (x265) or hardware (AMD, Nvidia, Intel).
