high quality for filmmaker color davinci resolve
  • Hello there
    I've been using vocoder and Rendering via GPU, but I haven't seen any better results
    can you tell me how to render with some video quality boost
    hi i use vocoder via davinci resolution at 6k 4k settings via gpu. the quality is not very good
    If you know how to improve the quality, send a screenshot, thanks in advance!
    my computer settings
    i7-11700k
    RTX 3060 12GB
    Einmal editiert, zuletzt von Vouk (10. September 2023 um 09:24) aus folgendem Grund: Ein Beitrag von donclips mit diesem Beitrag zusammengefügt.
  • Vouk 10. September 2023 um 09:22
  • For great quality, you'll need CPU encoding (e.g., x265), not GPU. If you want speed but are content with okay/decent quality, you would use GPU (e.g., NVENC).
    That said, there are quite a few threads on this site related to settings for getting the most out of your CPU/GPU encoding. I suggest you take a look through them.
    2 Mal editiert, zuletzt von Joe24 (11. September 2023 um 17:38)
