Vegas v21 does not see Voukoder Pro
  • Vouk 8. November 2023 um 08:40
  • Did you select Vegas 21 in the VoukoderPro installer options? You have to manually select your NLE from the list.
    Also, make sure you have the "Show Favorites Only" filter turned off in the "Render As..." list in Vegas.
    Einmal editiert, zuletzt von Joe24 (8. November 2023 um 09:02)
  • Vouk 7. Februar 2024 um 09:22
