After Effects using Voukoder Pro does not exit properly after rendering
  • Tested with AE 2022 and 2023, using voukoder Pro to render mp4, using the following settings.
    After rendering completes, AE freezes every time it tries to exit, even if the project is closed first.
    You can only force end the process using Task Manager.
    But with voukoder and connector everything works fine.
  • Vouk 28. November 2023 um 09:18
  • Tried test running in designer, no errors.
    The actual rendering process itself is no problem. The problem occurs after rendering is completed (or canceled after starting) and AE gets stuck when exiting.
  • Vouk 7. Februar 2024 um 09:23
