【solved】No audio samples left
  • Just a simple mistake about frame time base.
    I used Voukoder to export video in PR2023, but the exported video picture and sound got out of sync. The length of sound is correct, but picture seems to be static and the total time become too long, a 15min video became 18+hours.
    I tried h264, h265, with software and nvenc, but all output had same problem. I checked video and sound parameters, which was the same as PR default settings and usable for PR encoders. I used Windows Media Player and Potplayer to play the video and got the same result.
    with h264 software sometimes I got warning from PR said "Media Encoder!"
    [11:50:10] Frame #258: vRender: 17 us, vProcess: 6 us, vEncoding: 2072 us, aRender: 2029 us, aEncoding: 38519 us, Latency: 42779 us
    [11:50:10] Aborting audio renderer loop: No audio samples left!
    [11:50:10] Frame #259: vRender: 16 us, vProcess: 5 us, vEncoding: 2049 us, Latency: 2168 us
    [11:50:10] Frame #260: vRender: 21 us, vProcess: 6 us, vEncoding: 2076 us, Latency: 2169 us
  • Vouk 9. Dezember 2023 um 07:10
  • SimonZzz01 9. Dezember 2023 um 13:23
    Hat den Titel des Themas von „Video sound and picture out of sync: No audio samples left“ zu „【solved】No audio samples left“ geändert.
