15. Dezember 2023 um 18:31 #1 Is it possible to force the x264 encoder to use a constant bitrate? (Like mentioned here on the FFmpeg website) If so, which parameters do I have to pick?(btw: Voukoder is great software!)
19. Dezember 2023 um 09:42 Offizieller Beitrag #2 Yes, it is possible once I add the minrate and maxrate parameters to the options.Edit: Will be in the next build!
