help i cant export my file
  • [00:24:02] =============================================
    [00:24:02] Voukoder 13.3 (13.3.0)
    [00:24:02] by Daniel Stankewitz
    [00:24:02] ---------------------------------------------
    [00:24:02] AMD Ryzen 3 3100 4-Core Processor
    [00:24:02] 8 logical cores
    [00:24:02] 16313 MB system memory
    [00:24:02] Display #0 on: NVIDIA GeForce GTX 1660 Ti
    [00:24:02] Display #1 on: NVIDIA GeForce GTX 1660 Ti
    [00:24:02] Export started
    [00:24:02] Filename: C:\Users\shado\OneDrive\Рабочий стол\Valorant 2023.12.27 - 00.45.14.05.DVR_1.mp4
    [00:24:02] Application: Voukoder (Adobe Premiere)
    [00:24:02] - Video -------------------------------------
    [00:24:02] Frame size: 1920x1080
    [00:24:02] Pixel aspect: 1:1
    [00:24:02] Timebase: 2116766131/-1841018880 (-0.87 fps)
    [00:24:02] Interlaced: No
    [00:24:02] Encoder: h264_nvenc
    [00:24:02] Options: _computeCapability=7.5 _pixelFormat=yuv420p gpu=0 multipass=disabled preset=p4 profile=high qp=15 rc=constqp
    [00:24:02] Side data: <none>
    [00:24:02] Filters: <none>
    [00:24:02] Passes: 1
    [00:24:02] Color range: unknown
    [00:24:02] Color space: unknown
    [00:24:02] Color primaries: unknown
    [00:24:02] Color transfer: unknown
    [00:24:02] - Audio -------------------------------------
    [00:24:02] Timebase: 1/48000
    [00:24:02] Channels: 2
    [00:24:02] Encoder: aac
    [00:24:02] Options: _sampleFormat=fltp b=320000 profile=aac_low
    [00:24:02] Opening codec: h264_nvenc with options: gpu=0|multipass=disabled|preset=p4|profile=high|qp=15|rc=constqp
    [00:24:02] Failed opening codec: h264_nvenc
    [00:24:02] Unable to open video encoder: h264_nvenc
    [00:24:02] Closing encoders ...
    [00:24:02] Opening encoder failed! Aborting ...
  • Vouk 27. Dezember 2023 um 20:01
