If I try to render using SVT-AV1 in either CBR or VBR the render "finishes" immediately (which basically means it failed) but if you use CRF mode then it works. This was not an issue in 13.3.
CBR & VBR for SVT AV1 doesn't work in 13.4
- VEGAS Pro
Logan589XP -
1. Januar 2024 um 11:00
1. Januar 2024 um 11:49 Hat das Thema freigeschaltet. -
Does this version fix the issue for you? https://github.com/Vouk/voukoder/…oder-13.4.1.msi
CBR now works but VBR still doesn't.
Can you share your Voukoder log file, please?
Here it is.
