Renders cancel after a second of rendering with NVENC (VEGAS 17)
  • Hello there, sorry its my first time here but i got brought here from a discord server.
    It worked for me the first few times but for the last week it hasnt worked at all, it starts for 1 frame and then cancels Will link a video showing it too, im importing 60fps blurred clips and the project properties are also at the same as the usual (1080p60, resample off etc) and ive tried changing the project to 2k and 4k and still have had the same issue
    Logs will also be added as an attachment
    2024-01-03.txt
  • Vouk 3. Januar 2024 um 13:52
  • Code
    [12:41:47] Interlaced:      Top first
    The RTX GPU's can't encode interlaced videos anymore.
    Ooh, thanks a lot!
    Is there any way that i could get past this? I don't really know anything about ffmpeg/video stuff, so im pretty clueless
  • In the upper right corner of your Project Properties window, change the Field Order option to "Progressive". This will render your output video as progressive, instead of interlaced.
    3 Mal editiert, zuletzt von Joe24 (4. Januar 2024 um 07:46)
