Vegas 21 -- distorted video
  • This is what a render looks like using Vegas 21 and Vukoder (the newest but older also didn't work).
    I render in 954x720 resolution (1430x1080 also didn't work)
    Rencoding with Mainconcept goes smoothly.
    Screenshot is cropped.
    It seems the resolution is the problem -- if it's not divisible by 4, that's how it works out.
    But if I render losslessly and then manually render with ffmpeg, the resolution of 934x720 comes out correctly.
    I tried rendering today in 694x564 and 1050x1080 resolutions. In both cases the effect is as above, i.e. shifted chroma (?). Is there any chance to improve this?
    Einmal editiert, zuletzt von Vouk (17. Oktober 2024 um 10:10) aus folgendem Grund: 2 Beiträge von rgr mit diesem Beitrag zusammengefügt.
  • Vouk 10. Februar 2024 um 21:07
  • Vouk 24. April 2024 um 09:51
