Export Audio ONLY from DaVinci Resolve
  • I just installed Voukoder for DaVinci Resolve Studio, and I couldn't find the template or the option to export Audio ONLY like it does in Vegas Pro, and the reason I wanted Voukoder is to be able export from DaVinci Resolve 5.1 AC3 directly to DVD Architect. If I disable the Video in DR there is no option for Voukoder in Audio.
    Also, the ability to export video to .m2v like we do in VEGAS Pro using mainconcept template would be amazing.
    Hope you'd consider an option
    Thanks again
    Dave
  • Vouk 22. Februar 2024 um 07:42
