Feedback questions:No valid export configuration set,please configure Voukoder before saerting the export
  • Dear Author:
    In order to speed up the export of Adobe Media Encoder, I bought an A770 graphics card, but when PR queue to ME, there is always a prompt like "No valid export configuration set,please configure Voukoder before Starting the export", I chose H.264 (Intel QSV), and the rest are all defaults.
    I have selected H.264 (Intel QSV) and the rest are all defaults. I don't have similar problems with Nvidia cards. How can I solve this problem? Thanks for your help.
    I'm sorry! I'm Chinese, I don't quite understand what you're talking about, is it because I've set it up incorrectly, or is it a problem with my system, can you give a specific step by step?:/
    Einmal editiert, zuletzt von Vouk (21. März 2024 um 11:32) aus folgendem Grund: Ein Beitrag von anqiu mit diesem Beitrag zusammengefügt.
  • Vouk 21. März 2024 um 08:57
    Normally this message appears when you have not configured Voukoder yet, but the user wants to start an export. But you need to configure what encoders, muxer, etc you want to use.
