It keeps crashing when trying to render certain videos with Voukoder
The video renders fine when rendering with default Vegas presets, and Voukoder works fine when rendering different videos
Attached are the mediainfos of a video that renders fine and the one that crashes, along with the Voukoder log from the crashed render
I'm guessing it has something to do with the crashing video having variable framerate, since an encode of the same video but with constant framerate rendered fine
The below is copy-pasted from the crash window
Problem Description
  Application Name:    VEGAS Pro
  Application Version: Version 18.0 (Build 284)
  Problem:             Unmanaged Exception (0xe06d7363)
  Fault Module:        C:\WINDOWS\System32\KERNELBASE.dll
  Fault Address:       0x00007FF9840BCF19
  Fault Offset:        0x000000000002CF19
Fault Process Details
  Process Path:        C:\Program Files\VEGAS\VEGAS Pro 18.0\vegas180.exe
  Process Version:     Version 18.0 (Build 284)
  Process Description: VEGAS Pro
  Process Image Date:  2024-04-03 (Wed Apr 03) 04:41:40
Forgot to mention that I've tried everything I could find online like redownloading .NET 3.5, resetting preferences, reinstalling Vegas, reinstalling Voukoder and I also tried out a lot of render setting combinations
