Voukoder just not work today in AME and AE
- Kein Bug
alexvoz -
26. April 2024 um 10:36
26. April 2024 um 10:40 Hat das Thema freigeschaltet. -
Are you using Voukoder or VoukoderPro?
I used Voukoder all time and installed VoukoderPro today when Voukoder didn't want to work. Same problem
Please post a logfile from either Voukoder or the scene test from voukoderpro.
Where I can find logfile in Windows?
ThemaWhere do I find the log file?
Main log file
The main log file contains all log data for one single day:- Voukoder initialization
- All exported files
(Quelltext, 1 Zeile)
The files are named by the ISO date (yyyy-mm-dd).log:
Export specific log file
If you have "Create log next to the export file" enabled you can also find it - well ... - next to the exported file. This log file contains only the export relevant information.
Low level debugging
Sometimes its…Vouk20. April 2020 um 14:57 -
It's quite strange, but both versions worked. I created a new scene in VoukoderPro (I had to figure it out) and it rendered, and after that the usual Voukoder also started rendering. Reboot PC and all ok. Before I reboot PC too but didn't work. In log file at begin is some problem to file access amfrt64.dll
From what I can see the video resolution looks strange:
1059x1045
Most encoders only work with even resolutions where width and height have to be dividable by 4 or 8.
Hm. Its video exported from Photoshop.
AME Encoded this video to 1058x1044 by included MP4 codec.
You are right. It's all about resolution of the video. Thank you. I will check now. I thought that the Adobe software must-do everything correctly, but now I will know
26. April 2024 um 12:46 Hat das Label Kein Bug hinzugefügt.
