Audio Sync Bug on VoukoderPro v1.2.3
- Nicht behebbar
invert1337 -
5. Mai 2024 um 00:04
5. Mai 2024 um 00:28 Hat das Thema freigeschaltet. -
23. Juli 2024 um 12:13 Hat das Label In Bearbeitung hinzugefügt. -
Did you try enabling "Legacy decoding" in options? This option should be enabled anyway.
I remember this "bug" for years now. It's difficult and not really clean to work around bugs in the host application "VEGAS Pro" in an underlying piece of software. Please check rgr s post.
7. November 2024 um 05:57 Hat das Label von In Bearbeitung auf Nicht behebbar geändert.
