How can I tell that Voukoder is working with DaVinci Resolve?
    I'd like to use Voukoder to get around the Windows 10 bug on DaVinci Resolve that locks in exported audio quality to a maximum of 187 kbps. I'm trying to get it to 320 kbps like my source audio file.
    I followed the instructions for installing Voukoder as well as the DaVinci Resolve plugin.
    After downloading the DaVinci plugin, I unzipped the file and dropped the voukoder_plugin.dvcp.bundle folder (contents: \voukoder_plugin.dvcp.bundle\Contents\Win64\voukoder_plugin.dvcp) into the following directory:
    C:\ProgramData\Blackmagic Design\DaVinci Resolve\Support\IOPlugins
    I had to create the IOPlugins folder in "Support".
    I restarted my computer and tried to export my video again as an MP4 using the H.265 codec. In the "Audio" tab, the only available codec is AAC. I set "Track Data Rate" to 320 kbps, but the resulting file is still only 187 kbps.
    Yes, I am using the premium version of DaVinci Resolve.
    I've not touched the main Voukoder application. Is there something I need to do within the application, or DaVinci Resolve, that I've missed?
    Thank you.
  • Vouk 14. Mai 2024 um 06:16
    It should look like this if Voukoder (Both the main Voukoder app and the DVRS connector) is successfully installed:
    Note: You need to configure all settings (codecs, formats, ...) through Voukoder (Configure Voukoder ...)!
