Can't Export With Voukoder Pro
  • I am unable to make an export with Voukoder Pro. When I am trying to use Voukoder Pro to export in Davinchi Resolve Studio 18.6 on my PC it gives me no options under the Codec dropdown menu. Under the Codec menu it just says ' Voukoder Pro.' If I try to export I get an error message that says, ' Render Job failed as the current clip could not be processed. Codec is not open yet.'
    I also tried installed Voukoder Classic and adding the resolve connector in the file path C:\ProgramData\Blackmagic Design\DaVinci Resolve\Support\IOPlugins. In this case Voukoder did not even show up under the format options in the export menu.
    Please help! I need to be able to make higher quality exports for my job!
    Thanks,
    Lasha from Canada
  • Vouk 15. Mai 2024 um 07:17
    VoukoderPro works a bit different than the standard DVRS behaviour.
    You need to open the "Scene Designer" first and configure the output workflow first. i.e.:
    Then save that scene and select it here:
    Its more a less like a preset or template.
  • Vouk 23. Juli 2024 um 12:12
