How to get multi-channel audio output from multichannel track in DR?
  • I'm new. How do I (if possible) get a multichannel audio proresHQ file out of a multitrack timeline in davinci resolve? Where each track on the timeline exports to the same channel on the output file> thanks!8)
  • Vouk 12. Juni 2024 um 21:52
    You need to handle this in the DVR export settings. VoukoderPro then exports all tracks by default or you can export single tracks in the input node configuration.
