Output settings for finishing to create DCP
  • Hello!
    I'm exporting a short film out to be used to create a DCP for theatrical presentation.
    I have a few questions about how to best setup VoukoderPro to get the maximum quality.
    I did an export with these settings:
    Basically, I want to know if these settings will be sufficent for the creation of a DCP.
    Also, I'm not sure what "Mbs per slice" means. Is it the same as bitrate? I also see "Bits per mb" and I'm not sure how that relates either and if one or both should be set to certain value to best set up the export for DCP.
    Thanks in advance for your answers!
  • Vouk 14. Juni 2024 um 06:53
