Does not show in format in Premiere Pro 24.0
  • Vouk 25. Juli 2024 um 07:02
  • Vouk 25. Juli 2024 um 07:10
  • Sadly also Voukoder Pro is unavailable in Adobe CS6. Installed in C:\Program Files\Adobe\Common\Plug-ins\CS6\MediaCore, for both Premiere and After Effects, it sort of loads into the program because the name is briefly displayed on loading/splash screens in Premiere and Encoder (in After Effects it's harder to notice) - but still is unavailable in the export dialog.
    Other than that, the classic Voukoder with the proper connectors works as expected and can be used.
    The image attached shows where the "Voukoder Pro" option should be expected but it is not present there.
    I'm aware of this. Premiere CS6 is a 12 years old and does not support the features VoukoderPro is currently using. I'm not sure if CS6 can be still legally activated.
  • I'm aware of this. Premiere CS6 is a 12 years old and does not support the features VoukoderPro is currently using. I'm not sure if CS6 can be still legally activated.
    well someone (like me) can have it still activated since times immemorial on a hardware set from those times. it was the last version with one-time paid license, not a subscription. many people have that. still an enough platform for FullHD editing. no nvenc support because there were no nvenc then yet. with a well known hack one can enable CUDA support, but final render is still CPU-only. A nice toy from times past.
