Render has offset AAC audio for Vegas Pro 18
  • Apparently, the newest version of Voukoder Pro has a built in audio offset that was meant to re-sync AAC audio. However, it doesn't work well for earlier Vegas versions like 18. The image shows the example of the rendered audio being offset by a sample. I've tried PCM which has the synced audio, but doesn't work well for other software such as the Adobe programs. I can't even get rid of the offset either. Is there a solution to this? Thanks.
  • Vouk 21. September 2024 um 06:13
    I didn't add any audio offset to VoukoderPro. It seems VEGAS Pro fixed it in the latest version.
    But you can try getting rid of it in earlier versions by adding a delay filter to the scene:
  • I've tried the delay filter, but it had made it more delayed that I needed. I can't even use negative values on the filter. Also, the initial problem I have is that the render doesn't not add a delay, but instead removes a tiny bit of the audio.
    I've tried updating it to a newer version, but the problem still persists. It's both on Voukoder and VoukoderPro.
    Einmal editiert, zuletzt von Vouk (28. Oktober 2024 um 20:44) aus folgendem Grund: Ein Beitrag von clamman88 mit diesem Beitrag zusammengefügt.
  • Vouk 23. September 2024 um 09:18
