Latest Vuokoder stuck on Vegas Pro 22
  • Vouk 1. Oktober 2024 um 15:18
  • Vouk 7. November 2024 um 08:02
    Hat das Label Nicht behebbar hinzugefügt.
  • EDIT: I just realized I've posted in a wrong section, please move to Voukoder Classic Bug report.
    Sorry for the delay, it's a bit busy period for me (I have to publish 2 festival videos - read 11x4-5min live videos, 1 for each band - and a live classical concert - ~130min video - by december)...
    ...anyway unfortunally I still can't encode using Voucoder (classic) on Vegas 22.
    Render starts but immediately reaches 100% without ever finishing and/or generating any output. Anyway it don't crash.
    Here's a screenshot:
    Voukoder:
    Einmal editiert, zuletzt von forart.it (7. November 2024 um 10:36)
  • Done. It has exactly the same behavior/result...
    ...maybe it's a Vegas fault ?!?
    (note: no a/v fx used on the timeline but just transitions in a multicam edit. Embedded encoders works flawlessly)
  • If your Vegas output is 25p, then why even mention interlacing? Why would Voukoder care what format your raw footage was? All it sees is the Vegas output.
    I don't understand what you mean (my project/sources are 50i), anyway I wanna use Voukoder - FFMPEG - deinterlacing algos not Vegas ones.
    Einmal editiert, zuletzt von forart.it (24. November 2024 um 10:31)
