Davinci 19.0.2 closes when using Voukoder
  • Previously I used Davinci 18. Voukoder worked without problems. I saved videos in MP4 H265 or ProRes 422 (4K resolution).
    I updated Davinci to the latest version and I started having problems. If I choose MP4 H265 or ProRes (4K resolution), then on the first frame of the render Davinci closes (you can see it in the second photo). If I choose the native codec in Davinci, then the rendering goes without problems. The problem is that Davinci does not have ProRes (I use this for YouTube to get the maximum quality).
    What should I do and will there be new versions of Voukoder without these problems? I will post screenshots, with these settings Davinci crashes.
    However, if I select MP4 H264 in Voukoder, the rendering works (you can see it in the third photo).
  • Vouk 7. Oktober 2024 um 15:39
