Hello, I purchased Voukoder Pro today and got it set up in Vegas Pro 22 after a little bit of work. Unless I am doing something wrong, it looks like there are no presets available in my installation of Voukoder Pro. Is this normal? If so, is there a repository for presets I could use just to get up and running quickly. Thanks.
Voukoder Pro presets missing?
11. Januar 2025 um 17:10 Hat das Thema freigeschaltet. -
Yes, it is normal. There are no presets in Voukoder Pro yet. But you can use any FFmpeg presets and also the ones from the original Voukoder app.
Thanks for the response. I haven't used the original Voukoder app. Where can I get this so I can get the presets from it? Thanks
You can get it here: https://github.com/Vouk/voukoder/releases/tag/13.4.1 and the NLE connectors here https://github.com/Vouk/voukoder-connectors/
How exactly to import presets from the original Voukoder app?
Please write step-by-step instructions. -
I've started with converting the iAvoe presets for the x264 encoder. Import them with "Scene" > "Import ..." to the Designer App and "Scene" > "Save as ..." to your local drive.
