Well, here's another fun one. When the "YouTube" destination of the Export tab is set to use a Voukoder Pro preset, the UI in the Export panel gets all screwy, as seen in the attachment. I just toggled between two presets, and you can see what happens. Very odd. Trying to use the "Send to Media Encoder" or "Export" buttons doesn't do anything. Everything renders out perfectly fine in the "Media File" destination, but one of the reasons I pay for Premiere is for huge Media Encoder queues.
I'm not sure what kind of diagnostics you'd like? I'm not getting any errors, because it's not even making it to the moving parts, as far as I can tell. I've attached the scene (with an extra .txt extension), which is pretty simple, and the encoder profile in Premiere is basically the same.
[ed: one of these days I'm going to create a thread that's not about bugs & problems...]
