I am getting errors in after effects even though i am installing properly is there any fix for this?
after effects is not recognizing plugins
- Nicht behebbar
pardeep -
12. Februar 2025 um 19:07
12. Februar 2025 um 19:48 Hat das Thema freigeschaltet. -
What version of Voukoder Pro are you using?
latest version 2.0.7 and after effects 2020
I'll investigate it. It was working for me with the latest version of AfterFX.
ok sir let me know if you find any solution
Sorry, I can't install any version from 2020 from the Adobe cloud. Is yours a legal or pirated copy? Is it Mac or Windows?
16. März 2025 um 10:55 Hat das Label Nicht behebbar hinzugefügt.
