have Pro version and have reinstalled GPL and LGPL multiple times and different combonations, and still not showing the Resolve export menu. I tried the 0.13 connector from Github which just racks up the export time when pushing "start Render".
Im running Resolve 19.1.1, win11, i9 14900k, RTX 4090 and 128 DDR5..
Any ideas what this could be?
Davinci resolve 19 not showing Voukoder
- Nicht behebbar
markhobz -
13. Februar 2025 um 21:59
14. Februar 2025 um 06:07 Hat das Thema freigeschaltet. -
- First, did you select "DaVinci Resolve Studio" and verified the directories are correct?
- Which FFmpeg build did you install? The ones I have linked?
- Do you have DaVinci Resolve Studio? The paid version? Voukoder Pro doesn't work with the free version!
- Please don't mix up Voukoder components and Voukoder Pro components.
- If Voukoder Pro is installed correctly it should appear here:
16. März 2025 um 10:55 Hat das Label Nicht behebbar hinzugefügt.
