MOOV Faststart with Nvidia AV1
  • Hi, I am having issues rendering videos to Nvidia AV1/MP4 using Voukoder Pro.
    Even though I set the Movflags to Faststart, this setting doesn't seem to affect the render in Adobe Premiere.
    After render I don't get the usual extra delay while the atom is moved, nor does FFMPEG see the moov atom moved to the front.
    Is that a limitation of AV1 encoding? Or did I just forget to change any additional settings required? Never had this issue when using h.264 before. :)
  • Vouk 14. Februar 2025 um 19:01
  • Vouk 12. April 2025 um 13:06
    It depends on the implementation.
    ChatGPT explains it like this:
    Zitat
    Yes, technically: The MP4 container supports AV1 using the AV1 ISO-BMFF format, and tools like FFmpeg can place the moov atom at the beginning even for AV1.
    However, support depends on the muxer and player:
    • FFmpeg with -movflags +faststart works, but you must use libaom, libsvtav1, or other AV1 encoders that output compatible streams.
    • The AV1 stream must be correctly formatted according to the AV1 codec ISO Media File Format Binding specification (ISO/IEC 14496-15:2017 + amendments).
    • Some older players or browsers may not fully support AV1-in-MP4 yet, especially for streaming.
  • Vouk 12. April 2025 um 17:24
    Hat das Label von In Bearbeitung auf Kein Bug geändert.
