Unable to load Voukoder Pro.
26. Februar 2025 um 08:09 Hat das Thema freigeschaltet. -
Normally the installer is adding that variable automatically.
So the variable was not set after the installer has finished? Did you try to reboot your pc?
It has been restarted
