Uninnstall Voukoder Pro on MAC
  • Hi, I tested Voukoder Pro on MAC OS
    From today I have problem with Homebrew and all my Adobe products(Premiere, Encoder, Audition) crash on loading with error on "VoukoderPro.prm.bundle".
    I want to uninstall Voukoder Pro from my MAC OS, but i can't find unstruction how to do it.
    Can you help me?
  • Vouk 26. Februar 2025 um 18:02
    To uninstall the PremiereCC plugin of Voukoder Pro please delete VoukoderPro.prm.bundle from the directory /Library/Application\ Support/Adobe/Common/Plug-ins/7.0/MediaCore/. You can do this via the MacOS Terminal app.
    rm -rf /Library/Application\ Support/Adobe/Common/Plug-ins/7.0/MediaCore/VoukoderPro.prm.bundle
    Your Adobe apps should be working again after that.
