Voukoder Pro (Nvidia HEVC Profile level)
- Kein Bug
miki1hr -
15. März 2025 um 13:27
Maybe this is this related to this issue? Can you check?
ThemaPRORES 4444 XQ issues
Good Evening,
using the free version of VOUKODER i was able to export 4444 XQ prores files.
Now it seems to don't work with the last version using same parameters on PRORES_KS menu
HEEEEELPPPP!backlight6. März 2025 um 11:31 -
Hi,
Yes, that was the problem. After installing the latest version of ffmpeg, everything is fine now.
Thanks for the help.Best regards
12. April 2025 um 13:02 Hat das Label Kein Bug hinzugefügt.
