Setting up audio channels in Voukoder Pro
  • Hi, I just started tinkering with Pro (Premiere/Media Encoder), so sorry for a noob question. How do I set up the number of audio channels for the Audio Encoder node?
    So far I tried the EAC3 encoder with a couple of 5.1 and 2.0 tracks and noticed some strange/inconsistent behavior. No matter if I have a 5.1 or 2.0 track, when I set Media Encoder's Basic Audio Settings to Mono, Voukoder always seems to output a 5.1 track. To get a 2.0 output, I set the setting to Stereo and it seems to have worked. However, when I set it to 5.1 for a 5.1 audio, the job failed with an error. I only tried the last part that resulted in an error a couple of times on two jobs in a single session without a restart, so not 100% sure it's always repeatable, but it seems confusing so far. Am I missing something basic, or there no better way to deal with this and control audio channels and their order directly from inside Voukoder? Thank you.
    Einmal editiert, zuletzt von alex2310 (16. April 2025 um 17:01)
    Normally Voukoder Pro picks the audio layout that gets exported from Premiere / Media Encoder. I will investigate this.
    What error did you get? Did you check the Voukoder Pro log file?
  • Vouk 17. April 2025 um 09:21
  • Normally Voukoder Pro picks the audio layout that gets exported from Premiere / Media Encoder. I will investigate this.
    I didn't think of copying it at the time. I also noticed that I wasn't running the latest version after I posted this. I updated and I ran a couple of tests with a random 5.1 AC3 MKV sample:
    1. Exported as MONO. Output: a 1.0 track.
    2. Exported as STEREO. Output: a 2.0 track.
    2. Exported as 5.1 SURROUND. Output: ERROR.
    Error compiling movie.
    Export Error
    Exporter returned bad result.
    Writing with exporter: Voukoder Pro
    Writing to file: I:\test_1.mkv
    Around timecode: 00:00:00:00
    Component: Voukoder Pro of type Exporter
    Selector: 9
    Error code: -2147287026
    The VoukoderPro log doesn't show any new entries since the last successful encode.
    I kept the Voukoder settings the same for all tests: eac3, 320kbps. When the error occured, I tried a few things with no success:
    • raising the bitrate to 640kbps (in case 320 was too low for 6 channels)
    • changing the audio channel layout from 5.1 to 6 mono clips in the editor, just in case, and exporting again.
    • switching the export codec to AC3.
    • exporting through Premiere instead of Media Encoder.
    • loading a 7.1 test video (another MKV, TrueHD) and tried exporting that one at 5.1.
    Same error with all. I realize it's too obvious an issue for no one else to notice it and it's probably something peculiar on my end, but I don't know what can possibly be causing it. It's a clean, up-to-date Premiere/Media Encoder installation. I have Influx (an importer/decoder plugin, https://aescripts.com/influx/) installed which could be the thing that throws Voukoder off, but I configured it to only override not natively supported codecs so AC3 should still be decoded by Premiere. Weird.
    Oh, and a related question, if you can't set it up directly in Voukoder and there's only these three settings (mono, stereo, 5.1) that are available, how would you export something like a 7.1 file with a format that supports it?
    Einmal editiert, zuletzt von alex2310 (17. April 2025 um 19:05)
