x264 2-pass not playable in iPhone
  • Thank you for developing this encoder. Finally, I have time to try out your encoder.
    I use 2-pass encoding with ABR set to 2500kbps. The output video plays fine in Windows with MPC-HC, but I cannot stream it using AirVideoHD (http://www.inmethod.com/airvideohd) nor copy it to iPhone (using FileExplorer, https://www.skyjos.com/fileexplorer/) and play it. I also cannot play it using VLC (2.2.8) in Windows. I use x264 video, AAC audio with MP4 container.
    However, if I use CRF set to 23 (or any number), while everything else remains the same, AirVideoHD and FE and iPhone will play it nicely.
    Please see log file, screenshots and sample video that is not playable on iPhone.
    Merry Christmas!
  • Hi Vouk,
    Thanks for the quick reply. No, I don't have ffmpeg with x264 to try encode for iPhone. Or, do you mean using the "FFmpeg video codec #1" in the video encoder menu? But, that option does not have control for bit rates or quality.
    Anyway, I did try with latest version of Handbrake (1.2.0) and it gives good result. In fact, I started with modifying the setting on voukodor 1.1.3 to match exactly with Handbrake. I have attached the mediainfo outputs of Handbrake vs Voukodor as comparison. The main difference I see is the "Codec ID": HB: mp42, Voukodor: isom, and I don't see how to make Voukodor outputs with codec id "mp42". All other fields are almost identical, including the format profile and levels.
  • I play around with the output file and here is what I found:
    There are a couple of unrecognized lines in the video output file. Namely:
    $ mediainfo 10Sec.mp4
    General
    Complete name : 10Sec.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 5.42 MiB
    Duration : 16s 427ms
    Overall bit rate : 2 770 Kbps
    Encoded date : UTC 1904-01-01 00:00:00
    Tagged date : UTC 2018-12-25 08:29:25
    Writing application : Voukoder 1.1.3 (Premiere) - https://www.voukoder.org
    ©TIM : 00;00;00;00
    ©TSC : 30000
    ©TSZ : 1001
    I tried split up the audio and video streams with MP4Box and combine back again and the output file works great with iPhone:
    $ MP4Box -raw 1 10Sec.mp4 -out out.avc
    [iso file] Unknown box type .TIM
    [iso file] Unknown box type .TSC
    [iso file] Unknown box type .TSZ
    Extracting MPEG-4 AVC-H264 stream to h264
    $ MP4Box -raw 2 10Sec.mp4 -out out.aac
    Extracting MPEG-4 AAC
    $ MP4Box -flat -add out.avc -add out.aac out.mp4
    [avc-h264] Possible Variable Frame Rate: VUI "fixed_frame_rate_flag" absent.
    AVC-H264 import - frame size 1920 x 1080 at 29.970 FPS
    AVC Import results: 984 samples (994 NALUs) - Slices: 4 I 292 P 688 B - 2 SEI - 4 IDR
    Stream uses forward prediction - stream CTS offset: 2 frames
    AAC ADTS import - sample rate 48000 - MPEG-4 audio - 2 channels
    Saving out.mp4: Flat storage
    The recombined output from MP4Box works great with iPhone (attached mediainfo output for reference).
    So, it seems there is a problem with muxer. Thanks for looking into it.
  • Vouk 26. April 2019 um 13:29
    Hat das Label Geplant hinzugefügt.
