Elementary Stream generation
  • In the Multiplexer panel there is a nice list of containers but for my work flow I need to input elementary streams into the authoring tool (good old Encore). Yes, I can manually split the files but it would be great to have an "None" option for muxing. This should create for at least h.264 video streams a file type of .264. For the audio side the file type would match the audio selected (ac3, mp3, aac, etc).
    Thanks.
  • Vouk 26. April 2019 um 13:28
    Hat das Label Prüfung hinzugefügt.
