1.2.1 deblock parameter setting
  • for x264, setting deblock field to 0:0 results in deblock=1:-1:-1 being documented in the encoding parameters.
    Setting deblock field to 1:-1 gets documented as deblock=1:1:-1,
    -1:-1 sets as deblock=1:-1:-1,
    -1:-1:0 set as deblock=1:-1:-1
    documentation on x264 has it as a <alpha>:<beta> control set.
  • Did you set tune film? If so, this tune set deblock to -1:-1 by default, but in Voukoder UI it still shows 0:0. However encode will be with proper deblock -1:-1 and in MediaInfo will be deblock=1:-1:-1. In this case you can't use tune film and manualy change deblock to 0:0.
  • Vouk 26. April 2019 um 09:17
    This is a really interesting one. The colon is used internally by FFmpeg as a separator. I somehow need to replace the separators to some very unusual values which would be a breaking change to existing settings.
    Now:
    profile=slow,preset=medium,x264-params=abc=def:debock=1:2:xy=z
    Possible: (But it'd conflicts with the other comma separators)
    profile=slow,preset=medium,x264-params=abc=def:debock=1,2:xy=z
    Solution: (As a breaking change)
    profile=slow|preset=medium|x264-params=abc=def:debock=1,2:xy=z
    Seems I have to introduce a versioning here.
    btw. This also affects other, similar options (i.e. "partitions")
  • Vouk 26. April 2019 um 16:09
